ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
Roberden
Jan 13, 2022Tutor
I had same problem initially. My WIFI devices would stay connected to the router (I could ping one from another) but there was no internet access to my provider. At the same time, ethernet connected devices functioned as normal. After a couple calls to NetGear I got a support tech that had me reset the modem (to factory specs) and NOT enable the modem security (the armour temporarily free app) and also not enable the Smart Connect.
I did change my SSIDs and passwords and restored my Port Forwards. It has now going on for a month with no issues. The log is clean. I have concluded that the only item that made a difference was not enabling the armour security. Incidentally, I did eventually enable the Smart Connect and have had no issues.
So reset the modem and do not enable the 'free' security software and see if that helps.
VexedCAX30uzr
Jan 15, 2022Aspirant
Thanks for trying to help.
Armor security free trial ended and I didn't spend more $ for supposedly more security, so it is already disabled. I have tried with both enabling and disabling smart connect. Same issue. Basically I have to just reboot it every day. Ridiculous.
- ljmagyarJan 15, 2022Star
it is COMPLETELY ridiculous... for $250 modem, it should have more than 24 hours uptime.
