ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
Jan 29, 2022Guru - Experienced User
So you actually didn't get your CAX30 working. You returned it and bought a different branded modem.
ljmagyar
Jan 31, 2022Star
FURRYe38 wrote:So you actually didn't get your CAX30 working. You returned it and bought a different branded modem.
Correct. After a half dozen visits from Comcast and inexorable changes of channels and configurations, and hours of time on the phone with Netgear tech support, dumping it for something else was the only solution.
The CAX30 isnt listed in the model drop down (above). It is a COSTCO only brand and Netgear missed the mark.
- FURRYe38Jan 31, 2022Guru - Experienced User
Good Luck.
