ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
AnnoyedCAX30Uzr
Jan 31, 2022Aspirant
I have done all that and still there are issues. Whether I am 3 feet away from the modem router (same room) or 30 or 40 feet away (another room) the connection always show clear, connected, very good strength, etc. BUT IT'S NOT WORKING!! So: REBOOT, WAIT at least TWO minutes, power back on, etc etc etc. ad nauseum.
I'm just going to limp along, until I can save enough to buy another DIFFERENT BRAND
ljmagyar
Feb 01, 2022Star
AnnoyedCAX30Uzr wrote:I have done all that and still there are issues. Whether I am 3 feet away from the modem router (same room) or 30 or 40 feet away (another room) the connection always show clear, connected, very good strength, etc. BUT IT'S NOT WORKING!! So: REBOOT, WAIT at least TWO minutes, power back on, etc etc etc. ad nauseum.
I'm telling you... order one from Amazon - mine was on my doorstep at 5AM the day after I ordered it. The MotorolaMG8702 I bought hasn't had a problem since I installed it.
Return the one you bought to Costco - Check your receipt - if it is a 90-day thing, it will say so at the bottom (per the Costco front desk). I didn't even have a box and they took mine back. The new Motorola was just a few dollars more.
