iRyan
Jun 28, 2021Star
Nighthawk CAX30 connection issues after reserving DHCP IP address reservations under LAN Setup
I've been experiencing severe connection issues with my Nighthawk CAX30 cable modem router. If I go into my device LAN setup under advanced settings and attempt to make any DHCP IP address reservatio...
JohnnieWalker22
Aug 26, 2021Guide
Question, after you add the IP reservations. Are you able to go into, lets say, your laptop and manually add the IP. Does it work then? Unpractical, I know.. just wondering.
iRyan
Aug 26, 2021Star
No, unfortunately that didn't fix anything. One of the first things I did on all my devices was created static IP's and a full reset of each one. I want to test the reservations again soon, but I'm sure it will keep happening since there hasn't been another firmware release since the last time.
- olympos1625Dec 10, 2022NETGEAR Employee Retired
Hi iRyan,
Thank you for reaching out. We are sorry for not being able to get back to you immediately. Our support team is looking into this issue and would like to work with you
We would like to endorse you to NETGEAR Level 2 support team for callback. Please provide the following information:Name:
Email:
Phone:
Preferred schedule ( atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
