djtaktic
Sep 11, 2021Aspirant
Nighthawk cax30 Horrible speeds
I just bought a Nighthawk AX6 CAX30 because I wanted to improve my speeds at home. I use to have a Arris Modem and Nighthawk R7800 router and was getting speeds of at least 600mps consistently. Once ...
Sep 12, 2021Guru - Experienced User
What speeds do you get with a pc/laptop hardwired into the CAX30?
Are you testing over 2.4ghz or 5ghz? the CAX uses smart connect and device can be on either band. And 2.4ghz is a slow network.
- djtakticSep 12, 2021AspirantI am using whatever default settings came on the router. When I do a speed test thru the Nighthawk App on my phone or laptop that is wireless the app saying im getting 500-600mps…. But my XBOX series X which I know can handle much higher speeds is only getting 50-90mps download speeds which is worse then what I was getting with my old modem and router….. any help would be appreciated before I return the item
- plemansSep 12, 2021Guru - Experienced User
djtaktic wrote:
I am using whatever default settings came on the router. When I do a speed test thru the Nighthawk App on my phone or laptop that is wireless the app saying im getting 500-600mps---The app isn't accurate at speeds greater than 500mbps. Reason why is it hosts the test off the router and it rarely chooses the proper server. Hardwire a pc/laptop into your router and test it using the speedtest app or browser so you can select/change the test servers. Try several servers. …. But my XBOX series X which I know can handle much higher speeds is only getting 50-90mps download speeds which is worse then what I was getting with my old modem and router-----Getting these speeds wired? Wireless? over 2.4ghz? over 5ghz? Details are key to helping out. Plus the xbox is similar in that it doesn't always choose the best server for speedtesting. That's why we say hardwire a pc/laptop in and test that router. You can change servers to ensure the server is appropriate. ….. any help would be appreciated before I return the item- djtakticSep 12, 2021AspirantWired to my MacBook Air and went to Speedtest site and am getting 980mps…. When I connect my XBOX to the wireless 2.4g I am getting 100mps and when I connect it to 5g it is getting 200mps. My iPhone 12 is getting 640mps wireless the same distance away from the modem as the XBOX about 10 feet wireless and in the same room at the router/modem
