idealboy89
Feb 22, 2023Tutor
Nighthawk CAX30 I just downloaded v1.4.11.2
I just downloaded v1.4.11.2 from this page using my mobile internet and uploaded it to the router by logging into 192.168.1.1 and navigating to Advanced -> Administration -> Router Update
That ...
- Feb 24, 2023That is correct. I used the .bin file that was a part of the zip package
michaelkenward
Feb 23, 2023Guru - Experienced User
plemans wrote:
That link appears at the top of the Community page for this section.
https://kb.netgear.com/000065543/?_ga=2.5970099.1073564255.1670756476-997256614.1625128861
Here at least, the link goes nowhere.
Not very assuring when when Netgear tries to alert people to a problem with a broken link.
Bradylaura2000
Feb 23, 2023Aspirant
After everything broke yesterday, I moved to another (used) router for different connection failures. turns out Xfinity says they have an issue in my area, then xfinity texts me about this workaround so I think “maybe it’s me, not them”... I roll back to CAX, but the TM trick doesn’t work, I default the router, still nope. Then I read I should roll back the code. I’m 20 hours into this, worked from home off my work phone that I’m limited on data with poor signal. I’ve had weird issues where individual devices would lose connectivity the entire life of this modem:router.
Then I dig into the code and there’s stats from this month/last month and other odd remnants… did it default all the way!? Is it really xfinity or is it this coincidental update?? Am I going in circles? I’m in IT, how would an every day joe handle this when I’m near melt down status!?
I wish Costco would recall this turd. Good luck everyone, and thanks to contributors for your time and thoughts.
- FURRYe38Feb 24, 2023Guru - Experienced User
Downgrade the CAX30 to v1.4x if you still have WEB UI access to the modem. If you don't, try this to load the v1.4x FW file using a wired PC:
