idealboy89
Feb 22, 2023Tutor
Nighthawk CAX30 I just downloaded v1.4.11.2
I just downloaded v1.4.11.2 from this page using my mobile internet and uploaded it to the router by logging into 192.168.1.1 and navigating to Advanced -> Administration -> Router Update
That ...
- Feb 24, 2023That is correct. I used the .bin file that was a part of the zip package
trainwrek
Feb 24, 2023Aspirant
Hi,
When I unzip the file, i see a .bin file (CAX30-V1.4.11.2.bin). But when I look at CAX30 manual, it mentions that the firmware file should be either a .img or .chk file. Just want to make sure that .bin file is the one that you upload via web UI to get the firmware version to 1.4
Thanks
- idealboy89Feb 24, 2023TutorThat is correct. I used the .bin file that was a part of the zip package
