idealboy89
Feb 22, 2023Tutor
Nighthawk CAX30 I just downloaded v1.4.11.2
I just downloaded v1.4.11.2 from this page using my mobile internet and uploaded it to the router by logging into 192.168.1.1 and navigating to Advanced -> Administration -> Router Update
That ...
- Feb 24, 2023That is correct. I used the .bin file that was a part of the zip package
trainwrek
Feb 24, 2023Aspirant
Hi,
When I unzip the file, i see a .bin file (CAX30-V1.4.11.2.bin). But when I look at CAX30 manual, it mentions that the firmware file should be either a .img or .chk file. Just want to make sure that .bin file is the one that you upload via web UI to get the firmware version to 1.4
Thanks
idealboy89
Feb 24, 2023Tutor
