DavidNomo
Oct 28, 2022Aspirant
NightHawk CAX30 is rejecting connection
Hello,
My NightHawk CAX30 is rejecting wireless connection after password update.
When i try to connect it shows "The Wi-Fi network "NETGEARXX" requires a WPA2 password"
I have not changes anything on my Mac, before it was able to connect to same Wi-Fi without any issue.
Checked Advanced => Administration => Logs, it shows WLan access rejected: incorrect secuirty from Mac address......
can you tell me what is going on?
What device are you connecting with?
Did you use the forget this network feature then try to re-connect then re-enter the password?Revert the PW change on the CAX to what had been working if nothing else to see if this resolves.
Any special characters in the password configuration?
- DavidNomoAspirant
What device are you connecting with? FROM MacBook
Did you use the forget this network feature then try to re-connect then re-enter the password? I did it, also refreshed DHCP tooRevert the PW change on the CAX to what had been working if nothing else to see if this resolves. Yep changed back, also rebooted CAX
Any special characters in the password configuration? Yes, but it was working before the issue
Please try something simple with out any special characters and see.
Is this the only device that is having problems or do all devices see this?
