coawarren
May 08, 2024Aspirant
Nighthawk CAX30 password not working after Factory Reset
I wasn’t able to connect to my 2.4ghz networks, but could connect to 5ghz. So, I did a factory reset to try fresh. Now, the network and password printed on a sticker at the bottom of the Nighthawk ...
- May 15, 2024
SOLUTION: Router defaulted to name: NETGEAR, but should have been NETGEAR50. The password on the bottom sticker wasn't working. This was after the 30/30/30 factory reset.
Password is: 1234567890
I was able to get this after buying an ethernet adapter and reseting the router settings online. Hope this helps someone in the future.
coawarren
May 15, 2024Aspirant
May 15, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
