kjculbertson
May 16, 2023Aspirant
Nighthawk CAX30 reverts to default network name and password
When our power comes back on after being out, I find that my Nighthawk CAX30 reverts back to the default network name and password. We have cameras on the network that we count on when gone and if t...
kjculbertson
May 20, 2023Aspirant
App Version 2.26.0.2884
Firmware Version v1.4.11.2
May 22, 2023Guru - Experienced User
How was the system updated? Auto update or did you manually apply FW with a wired PC and web browser?
- kjculbertsonMay 25, 2023Aspirant
Auto update
- FURRYe38May 25, 2023Guru - Experienced User
I would try this, manually download the v.2 FW file for the CAX30 and manually apply it with a wired PC and web browser:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Once it's processed the file and is back to ready, Factory reset the modem and setup from scratch:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Once it's setup from scratch. Once setup, save off a back up configuration to file:
