paragkhag
Jun 02, 2023Follower
Nighthawk CAX30S - Xbox One X My voice isn't working
Hey guys, I just got this router/modem and I've set up all the port forwarding for my Xbox. I can hear other people talking, but my voice is not coming through. Has anyone else had this issue? ...
michaelkenward
Jun 02, 2023Guru - Experienced User
paragkhag wrote:
They are now passing the buck to Xbox support saying it's their problem, when my old router/modem worked fine (another Netgear product) so clearly it is not the Xbox's problem.
That is the natural first place to look.
Unfortunately, the Xbox is a well known source of problems.
Search - NETGEAR Communities – Xbox my voice
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
