ecolucci
Sep 10, 2023Tutor
Nighthawk CAX30S LAN Configuration
I have a Netgear Nighthawk CAX30S that I am beginning to configure. In the Attached Devices section, I see a wired device that automatically was assigned an IP address of 192.168.1.2 before I even b...
- Sep 11, 2023
For what it’s worth, I worked out the source of my trouble: an addled brain…. A large part of my confusion is that my tablet and iPod are in fact using two MAC addresses thanks to a privacy feature called Private Wi-Fi Address, which either is turned on by default and went unnoticed by me, or I turned it on when I first got those two devices and then promptly forgot all about that feature. This means the Attached Devices list is correct, and my “need” for adding the “correct devices” as reserved addresses in the DHCP pool to “force” my router to recognize those devices never existed so I deleted them. My LAN configuration is clean now with everything working as it should--with the possible exception of my brain….
michaelkenward
Sep 10, 2023Guru - Experienced User
ecolucci wrote:
There must be a way for me to assign static IPs to certain devices and have the CAX router recognize those static IPs so that the router does not assign those same IPs to other devices and create traffic conflicts.
If you assign what you call a "static" IP address to a device, then that IP address will show up in the router as an attached device. (It isn't an exclusive use of the "static" term, but that is often used for your WAN IP address, which is why Netgear uses that label when it talks about the settings from your ISP.)
Giving a device an IP address on your network does not make it invisible to the router. It will add it to your table of devices
I see this all the time for the NAS storage and printers on my network.
ecolucci
Sep 10, 2023Tutor
I don’t think we are communicating. I am not sure what you are getting at when you refer to my use of the phrase static IP address. I am not using the phrase incorrectly if that is what you are suggesting. In any event, that is not my point.
My point is that I manually am configuring certain of my devices with static IP addresses; I do not want my router to dynamically assign IPs to those certain devices. However, my CAX30 modem-router is not automatically registering these devices as having static IP addresses and dynamically reassigns those same IP addresses to other devices on my network. This creates a conflict whereby multiple devices on my network simultaneously have the same IP address, which should not happen.
My understanding is that when a router is not able automatically to recognize a device having a static IP address, there usually (always in my 30-some-years experience) is a way to force the router to do so. Although I have used many pieces of Netgear equipment in the past including older routers, I am not as familiar with these newer models and their software. So as yet, it has not been evident to me where this is done in the online administrator software.
You wrote earlier, “It does allow you to make an "Address Reservation" but that is something else.” Actually after five phone calls and several hours with multiple Netgear technical-support specialists (I just got off the phone with them), it turns out that is precisely where I am to force my router into recognizing my assigned static IP addresses.
After I logged in, I was instructed to select the Advanced tab, then select Setup in the left navigation menu, and then select the LAN Setup submenu. Once on that page, there is a location near the bottom whereby I can add those devices under Address Reservation. Once added and saved, the router supposedly no longer dynamically will assign those specific IPs to any other of my devices.
I emphasized supposedly above because when I check a different section of the CAX30 router software (Advanced > Administration > Attached Devices) I still see two devices with duplicate IP addresses to the devices listed under Address Reservation. I know they are different devices because they have different MAC addresses. Meanwhile, those same two devices with the “correct” MAC addresses are not listed under Attached Devices. My other devices now listed under Address Reservation correctly appear under Attached Devices; only two do not. So although this appears to be the correct solution to one problem, this solution does not appear to be working entirely as it should.
When I spoke to Netgear tech support, I queried whether this could be a bug in the firmware (I just installed a recently released update last night). I was told they don’t know the reason for this discrepancy but are escalating the problem among their support staff and will get back to me sometime during the next 24-48 hours. Hopefully, they will have a solution. If not, I probably will drop the matter since this already is taking more time to resolve than it should take. If only two/four devices on my LAN have potential traffic conflicts, I think I can live with that….
- FURRYe38Sep 10, 2023Guru - Experienced User
Be sure to understand that STATIC IP ADDRESSES are set ON devices themselves and reside OUTSITE of a host routers default DHCP IP address pool.
IP ADDRESS RESERVATIONS are set ON the host router and with in the host routers default DCHP IP address pool.This is standard networking practice for many a year.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerThen you have room on either side of the pool for STATIC configured devices. I've been using this for years on ANY router I put online. Even with my CAX30.
- ecolucciSep 10, 2023Tutor
"STATIC IP ADDRESSES...reside OUTSITE of a host routers default DHCP IP address pool." This is the way my router currently is configured although I did not have it set up this way originally. I adjusted the DHCP pool after the fact, unplugged everything, and restarted the CAX30. I thought that would have reset everything. However as of this writing, the problem persists: two IP addresses for two devices (iPod Touch and iPad) are replicated in the Address Reservation list and in the Attached Devices list.
I asked myself if it is possible those two devices have two WiFi MAC addresses without my previously being aware of this possibility, but I checked both devices more than once and also checked my settings from my previous router's configuration, and I cannot see what I am missing--if anything. Out of curiosity, you stated you have a CAX30. What firmware are you on? Mine is using Firmware Version V1.4.12.2.
- FURRYe38Sep 11, 2023Guru - Experienced User
You might "forget this" on each apple device, then disable the wifi radios on the apple devices, then power OFF the CAX30 for 30 seconds then back ON. After the CAX30 is bac online, enable the wifi radios, ONE at a time, then reconect one at a time and monitor the IP address seen on the CAX30.
Also be sure to disable any MAC Address randomizers on Apple devices before connecting:
Been months since I had it online so I don't remember off hand. Been testing a CAX80. I run same DHCP pool configuration on the 80.
- michaelkenwardSep 11, 2023Guru - Experienced User
I did not say that you were using the term incorrectly. I said that you used it in a way that might lead to confusion. (Another ambiguous term with several meanings is "Bridge mode".) Regular visitors to this place are more likely to recognise the term "fixed IP address".
Search - NETGEAR Communities – "fixed ip address"
This is really where the problem lies. The router should not reallocate those fixed IP addresses to something else.
However, my CAX30 modem-router is not automatically registering these devices as having static IP addresses and dynamically reassigns those same IP addresses to other devices on my network.I have had fixed/static IP addresses on devices for years. Mostly for a printer and NAS storage that I want to be able to get at with a browser. None of the routers I have used has a "static" flag in the router's tables. The router has simply showed the fixed IP address as owned by the devices in question. It hasn't played games and reused a "fixed" IP address for other devices.
You wrote earlier, “It does allow you to make an "Address Reservation" but that is something else.” Actually after five phone calls and several hours with multiple Netgear technical-support specialists (I just got off the phone with them), it turns out that is precisely where I am to force my router into recognizing my assigned static IP addresses.There have been conversations here over the benefits of using reserved versus fixed/static IP addresses. A regular here who knows more about this stuff than I do – and can explain things clearly – suggested that reservations would be better. But there isn't much in it when it comes to the final result.
If you use an "Address Reservation" in the router you shouldn't need to set a fixed IP address on a device. The router does it and the effect should be the same. You seemed to be determined to have IP addresses fixed at the device level, which is why I said that this is a different function.
I can see that a fixed IP address can have advantages in you can change routers and not have to faff around with reservations.
If you go back to your first message you will see that it is thin on details. It took several iterations to get to where we are now. You have found problems with your router that Netgear can't explain.
- ecolucciSep 11, 2023Tutor
“I can see that a fixed IP address can have advantages in you can change routers and not have to faff around with reservations.” Exactly.
“If you go back to your first message you will see that it is thin on details.” Yep, I was at fault there. I also noticed—after rereading the entire thread—that I started on one topic with the intention to start a different discussion pertaining to a second related topic but then completely unintentionally blended the two topics together into this single discussion thread. Anyway, the matter is resolved now, and—as I stated elsewhere—I do appreciate the time you and FURRYe38 expended to try to help.
