ecolucci
Sep 10, 2023Tutor
Nighthawk CAX30S LAN Configuration
I have a Netgear Nighthawk CAX30S that I am beginning to configure. In the Attached Devices section, I see a wired device that automatically was assigned an IP address of 192.168.1.2 before I even b...
- Sep 11, 2023
For what it’s worth, I worked out the source of my trouble: an addled brain…. A large part of my confusion is that my tablet and iPod are in fact using two MAC addresses thanks to a privacy feature called Private Wi-Fi Address, which either is turned on by default and went unnoticed by me, or I turned it on when I first got those two devices and then promptly forgot all about that feature. This means the Attached Devices list is correct, and my “need” for adding the “correct devices” as reserved addresses in the DHCP pool to “force” my router to recognize those devices never existed so I deleted them. My LAN configuration is clean now with everything working as it should--with the possible exception of my brain….
ecolucci
Sep 10, 2023Tutor
I don’t think we are communicating. I am not sure what you are getting at when you refer to my use of the phrase static IP address. I am not using the phrase incorrectly if that is what you are suggesting. In any event, that is not my point.
My point is that I manually am configuring certain of my devices with static IP addresses; I do not want my router to dynamically assign IPs to those certain devices. However, my CAX30 modem-router is not automatically registering these devices as having static IP addresses and dynamically reassigns those same IP addresses to other devices on my network. This creates a conflict whereby multiple devices on my network simultaneously have the same IP address, which should not happen.
My understanding is that when a router is not able automatically to recognize a device having a static IP address, there usually (always in my 30-some-years experience) is a way to force the router to do so. Although I have used many pieces of Netgear equipment in the past including older routers, I am not as familiar with these newer models and their software. So as yet, it has not been evident to me where this is done in the online administrator software.
You wrote earlier, “It does allow you to make an "Address Reservation" but that is something else.” Actually after five phone calls and several hours with multiple Netgear technical-support specialists (I just got off the phone with them), it turns out that is precisely where I am to force my router into recognizing my assigned static IP addresses.
After I logged in, I was instructed to select the Advanced tab, then select Setup in the left navigation menu, and then select the LAN Setup submenu. Once on that page, there is a location near the bottom whereby I can add those devices under Address Reservation. Once added and saved, the router supposedly no longer dynamically will assign those specific IPs to any other of my devices.
I emphasized supposedly above because when I check a different section of the CAX30 router software (Advanced > Administration > Attached Devices) I still see two devices with duplicate IP addresses to the devices listed under Address Reservation. I know they are different devices because they have different MAC addresses. Meanwhile, those same two devices with the “correct” MAC addresses are not listed under Attached Devices. My other devices now listed under Address Reservation correctly appear under Attached Devices; only two do not. So although this appears to be the correct solution to one problem, this solution does not appear to be working entirely as it should.
When I spoke to Netgear tech support, I queried whether this could be a bug in the firmware (I just installed a recently released update last night). I was told they don’t know the reason for this discrepancy but are escalating the problem among their support staff and will get back to me sometime during the next 24-48 hours. Hopefully, they will have a solution. If not, I probably will drop the matter since this already is taking more time to resolve than it should take. If only two/four devices on my LAN have potential traffic conflicts, I think I can live with that….
Sep 10, 2023Guru - Experienced User
Be sure to understand that STATIC IP ADDRESSES are set ON devices themselves and reside OUTSITE of a host routers default DHCP IP address pool.
IP ADDRESS RESERVATIONS are set ON the host router and with in the host routers default DCHP IP address pool.
This is standard networking practice for many a year.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Then you have room on either side of the pool for STATIC configured devices. I've been using this for years on ANY router I put online. Even with my CAX30.
- ecolucciSep 11, 2023Tutor
"STATIC IP ADDRESSES...reside OUTSITE of a host routers default DHCP IP address pool." This is the way my router currently is configured although I did not have it set up this way originally. I adjusted the DHCP pool after the fact, unplugged everything, and restarted the CAX30. I thought that would have reset everything. However as of this writing, the problem persists: two IP addresses for two devices (iPod Touch and iPad) are replicated in the Address Reservation list and in the Attached Devices list.
I asked myself if it is possible those two devices have two WiFi MAC addresses without my previously being aware of this possibility, but I checked both devices more than once and also checked my settings from my previous router's configuration, and I cannot see what I am missing--if anything. Out of curiosity, you stated you have a CAX30. What firmware are you on? Mine is using Firmware Version V1.4.12.2.
- FURRYe38Sep 11, 2023Guru - Experienced User
You might "forget this" on each apple device, then disable the wifi radios on the apple devices, then power OFF the CAX30 for 30 seconds then back ON. After the CAX30 is bac online, enable the wifi radios, ONE at a time, then reconect one at a time and monitor the IP address seen on the CAX30.
Also be sure to disable any MAC Address randomizers on Apple devices before connecting:
Been months since I had it online so I don't remember off hand. Been testing a CAX80. I run same DHCP pool configuration on the 80.
