xyz_13
Dec 04, 2022Aspirant
Nighthawk CAX80 - cannot access website
I cannot access a website when connected to my CAX80 modem/router. I get a "404 - page not found error". I tried to access via multiple web browsers/devices, cleared cache/cookies, cleared my local D...
Dec 04, 2022Guru - Experienced User
Try a difference browser and PC.
Can you access 192.168.100.1?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- xyz_13Dec 04, 2022Aspirant
Already attempted multiple browsers and PC. This is either a router or ISP issue as I can access the website on the same laptop I was having issues with when connected to my mobile hotspot. Yes, I can access the router's admin portal. Resetting the device was my last resort but I may have to...
- FURRYe38Dec 04, 2022Guru - Experienced User
FR and setup from scratch using a wired pc and web browser...
