jrayner
Sep 13, 2023Aspirant
Nighthawk CAX80 - Can't upload to Slack or Shotgrid
Hello, for the longest time I've been having trouble with my NightHawk CAX80. Purchased end of 2022, since then I've had trouble with uploads. Downloads are fine, but uploads fail 90% of the time, pa...
jrayner
Sep 14, 2023Aspirant
Thanks so much FURRYe38 , I will try these out as soon as I can get Comcast out here.
I'm using the CAX80 as my modem and my router, btw, in case that changes anything.
So these correctables and uncorrectables are all bad to see right? Should I expect to see none of those in the diagnostic report, in a properly functioning modem/coax cable setup?
Sep 14, 2023Guru - Experienced User
When there are a ton of numbers seen and accross all channels ya, not good. Usually a bad cable or connection or possible cable splitter causing these values to go up. Should be mostly zeros or very low value numbers seen here.
