aantiix
Aug 04, 2023Aspirant
Nighthawk CAX80 - Guest Network Options
I'm looking at purchasing a new router and leaning towards the AX6000 WiFi Cable Modem Router (CAX80) I've contacted Netgear 3x so far and they can't seem to give me a straight answer, just keep quoting the user manual, which doesn't answer my question, so I'm hoping someone in the community can help
I see in the manual there is an option for "Allow guests to see each other and access my local network". However, what I want is for guest devices to have access to the internet, be able to see other devices on the Guest network, but not have access to my local network. I am trying to find out if this is the default functionality if I don't check that box, or if this is not possible with this router. I was hoping to isolate my IoT devices on the guest network via this method, as I'm currently doing with an older Archer router, but I'm not sure if this is possible with the Nighthawk Modem/Router.
Well possible that NG may close having guest devices access to each other. This has been a security risk over time and NG may close this. Not sure if or when that might happen. Guest Network works normally for internet access.
- Ihatenetgear19Aspirant
I have the exact same problem. I enabled all of the settings for the guest network and it will not broadcast the SSID. I called Netgear support and they told me I would have to buy a Netgear armor package in order for them to help me. They KNOW their nighthawk router/modem has problem with the guest network turning on and they want customers to pay for help. They put out a garbage product with issues and instead of fixing them they want customers to pay for their product to work even though the guest network should work out of the box. Unfetter greed and a lack of empathy for customers struggling with their terrible products. Netgear are a bunch of crooks putting out garbage products and demanding customers pay for support.
Guest Network is isolated from the main LAN.
- aantiixAspirant
Understood. However, what I'm wondering is if Guests can see each other and access the internet while remaining isolated. Some routers don't allow internet access unless you allow them to interact with local network, others don't allow Guests to see each other.
