dcastro
Jan 16, 2023Aspirant
Nighthawk CAX80 Admin Portal Stopped Working
Hello, I have been using a Nighthawk CAX80 router for a month now and the admin portal has been working fine. Suddenly, two days ago, certain pages have stopped working. Specifically, I canno...
- Jan 16, 2023
On second thought, please ignore.
I decided to reboot the router again just to make sure it didn't help, but in fact everything is working now after rebooting.
Thanks!
Jan 16, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
