TroutFisher
Apr 29, 2025Follower
Nighthawk CAX80 AX6000 - Trend Micro, Firefox and Edge not functioning
I recently purchased this product with eager anticipation for the increased speed, range, and stability over my old modem-router. After 4 days of frustration and anger I am about 4 to 5 days away fr...
Apr 30, 2025Guru - Experienced User
1. Why are you turning it off? I haven't shut mine off in years (other than to swap it out)
2. Trendmicro is giving you these issues? What happens if you disable it?
3. Its only on the 1 pc?
4. If its only on the one PC, did you try upgrading it to windows 11?
5. Does any other device at all have issues?
The driver update for other devices is normal. Upgrading to AX caused a lot of devices to need to be updated to support it.
