dmiburn1
May 22, 2022Aspirant
Nighthawk CAX80 conflicted
Good morning, I am so confused as to what is happening with this cable modem router. While I am able to use wifi on my phone, computer, and laptop, and stream movies/shows, the nighthawk app says th...
May 22, 2022Guru - Experienced User
what firmware version are you on?
Are you connecting with ipv6?
Have you tried using a different dns provider?
dmiburn1
i am unable to see that in the app because the app continues to say offline.
as for the app itself that was recently updated.....is there another way to see firmware?
i have not tried another dns provider.....
- plemansMay 22, 2022Guru - Experienced User
Try logging in through the browser. I prefer that method to the app anyway.
