Paul__G
Jul 30, 2020Aspirant
Nighthawk CAX80 Connectivity Issues with 2018 Samsung QN55Q6FNA TV Plus
I have also posted this to Samsung community boards because at the moment I'm still not sure who owns this issue! To start off this long winded explanation of a problem I will say I have a 2018 S...
brsox88
May 20, 2021Tutor
The solution is to use a different router, Samsung and Netgear have yet to come out with a firmware update that addresses this issue. It's most likely some imcompatibility since the CAX 80 is so new compared to these older TV's.
ronpro
May 27, 2021Guide
You probably tried this but, I have seen it before on some TV's. Set Static DNS in you device ie. TV. 8.8.8.8 and 8.8.4.4. I also had it twice to where NTP was not passing to TV. Ron
