dbmdude
Jun 17, 2022Aspirant
Nighthawk CAX80 disconnecting internet @ exactly same time every day
I am having a really hard time because sadly I cannot figure out what is causing this issue - ISP, Cable Modem, etc My cable modem shuts off internet (not it does not shut down) every day @ 10AM ...
dbmdude
Jun 18, 2022Aspirant
Hardware Version 1.01
Firmware Version 2.1.3.7
Cable Firmware Version 1.02.08
Bear in mind this problem occurs @ exactly 10am pacific every day.
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Sat Jun 18 13:58:48 2022
Startup Procedure
Acquire Downstream Channel: 675 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 41 675000000 Hz -0.9 dBmV 38.2 dB 203 2
2 Locked 256 QAM 13 495000000 Hz -0.5 dBmV 39.4 dB 335 20
3 Locked 256 QAM 14 507000000 Hz -0.5 dBmV 39.3 dB 326 17
4 Locked 256 QAM 15 513000000 Hz -0.4 dBmV 39.3 dB 268 6
5 Locked 256 QAM 16 519000000 Hz -0.4 dBmV 39.4 dB 278 30
6 Locked 256 QAM 17 525000000 Hz -0.5 dBmV 39.2 dB 302 6
7 Locked 256 QAM 18 531000000 Hz -0.6 dBmV 39.1 dB 300 9
8 Locked 256 QAM 19 543000000 Hz -1.4 dBmV 39 dB 280 7
9 Locked 256 QAM 20 549000000 Hz -1.2 dBmV 39 dB 286 7
10 Locked 256 QAM 21 555000000 Hz -0.9 dBmV 39.1 dB 263 9
11 Locked 256 QAM 22 561000000 Hz -0.9 dBmV 39 dB 256 11
12 Locked 256 QAM 23 567000000 Hz -0.8 dBmV 39 dB 269 6
13 Locked 256 QAM 24 573000000 Hz -0.8 dBmV 39 dB 249 3
14 Locked 256 QAM 25 579000000 Hz -0.8 dBmV 39 dB 245 1
15 Locked 256 QAM 26 585000000 Hz -0.8 dBmV 39 dB 240 18
16 Locked 256 QAM 27 591000000 Hz -0.9 dBmV 38.9 dB 246 8
17 Locked 256 QAM 28 597000000 Hz -0.9 dBmV 38.8 dB 232 9
18 Locked 256 QAM 29 603000000 Hz -0.9 dBmV 38.8 dB 230 5
19 Locked 256 QAM 30 609000000 Hz -0.9 dBmV 38.7 dB 238 12
20 Locked 256 QAM 31 615000000 Hz -1 dBmV 38.7 dB 252 1
21 Locked 256 QAM 32 621000000 Hz -1 dBmV 38.7 dB 223 8
22 Locked 256 QAM 33 627000000 Hz -1.2 dBmV 38.5 dB 228 8
23 Locked 256 QAM 34 633000000 Hz -1.3 dBmV 38.4 dB 231 6
24 Locked 256 QAM 35 639000000 Hz -1.4 dBmV 38.3 dB 214 6
25 Locked 256 QAM 36 645000000 Hz -1.4 dBmV 38.4 dB 204 6
26 Locked 256 QAM 37 651000000 Hz -1.3 dBmV 38.4 dB 221 2
27 Locked 256 QAM 38 657000000 Hz -1.3 dBmV 38.5 dB 198 9
28 Locked 256 QAM 39 663000000 Hz -1.2 dBmV 38.4 dB 206 1
29 Locked 256 QAM 40 669000000 Hz -1.1 dBmV 38.3 dB 204 5
30 Locked 256 QAM 42 681000000 Hz -0.9 dBmV 38.5 dB 208 5
31 Locked 256 QAM 43 687000000 Hz -0.7 dBmV 38.6 dB 183 11
32 Locked 256 QAM 44 693000000 Hz -0.8 dBmV 38.5 dB 163 2
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 12 5120 Ksym/sec 35600000 Hz 42.8 dBmV
2 Locked ATDMA 9 5120 Ksym/sec 16400000 Hz 42.8 dBmV
3 Locked ATDMA 10 5120 Ksym/sec 22800000 Hz 42.8 dBmV
4 Locked ATDMA 11 5120 Ksym/sec 29200000 Hz 42.8 dBmV
5 Locked ATDMA 13 2560 Ksym/sec 40400000 Hz 45.8 dBmV
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 722000000 Hz -0.02 dBmV 38.5 dB 1246 ~ 2849 736411644 198929956 26
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
Jun 19, 2022Guru - Experienced User
Got lots of Correct and un-correctables that should be zero. Something the ISP needs to look into.
