somuelchris
Dec 17, 2022Aspirant
Nighthawk CAX80 DNS and static IP issue.
Hi, Here are the issues I have seen on CAX80. Fist Issue: I removed all the IP from the DNS. I found out that I was able to access internet without any issue. I wanted to block random IP and the ...
Dec 17, 2022Guru - Experienced User
Not sure what you mean by you removed all IP from the DNS settings.
In terms of static ip address, have you used reserved IP address?
- somuelchrisDec 22, 2022Aspirant
Thanks for following up 🙂
When I applied Primary DNS (for example X.X.X.X) from the Linux box. The Linux box sorts the IP with the blacklist.
Linux Box has 8.8.8.8. - I have internet through the google and its sorted out to X.X.X.X IP and that IP I have put on Primary DNS.
When I remove 8.8.8.8 means to empty then I should not have any internet to pass through the modem.
--- Apply these changes works fine with c7000 modem. But on this CAX80 - The internet gets connected through. This is a problem because allowing internet out from the CAX80 is not acceptable. I reached out to netgear chat team and they asked me to reach to internet provider and they are referring back to the netgear.
I am in a loop of netgear and spectrum with no solution.
