somuelchris
Dec 17, 2022Aspirant
Nighthawk CAX80 DNS and static IP issue.
Hi, Here are the issues I have seen on CAX80. Fist Issue: I removed all the IP from the DNS. I found out that I was able to access internet without any issue. I wanted to block random IP and the ...
michaelkenward
Dec 17, 2022Guru - Experienced User
somuelchris wrote:
I have these modem too - AC1900/C7000, and it works with out any issue.
The C7000 is a modem router. Are you adding that to the CAX80 ?
Paying $400-500 and not able set static route on this modem.
What does that mean? What are you trying to do and what happens?
Take a deep breath, go back to basics and start from scratch.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
