Acelona
Sep 10, 2023Aspirant
Nighthawk CAX80 Ethernet Ports Not Working
Recently bought a new TV. When I did I unhooked everything from my setup and was only running wi-fi for a few days after installation. Wi-fi works as it should but now none of the ethernet ports will ...
- Sep 16, 2023
And you did power OFF the modem for 1 minute then back ON?
I'd get to NG support and see if there is an RMA option:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Sep 11, 2023Guru - Experienced User
Whos the ISP that the CAX80 is connected too?
Try a 30-30-30 reset on the CAX80 with all ethernet connected devices disconnected from the LAN ports.
Acelona wrote:
Recently bought a new TV. When I did I unhooked everything from my setup and was only running wi-fi for a few days after installation. Wi-fi works as it should but now none of the ethernet ports will work. They do not even light up when a device is plugged in and powered on. Ibhave tried power cycling, hard reset up unit, and multiple cat6 cables. I am scratching my head here. Any idea what went wrong.
Acelona
Sep 16, 2023Aspirant
It is oit of warranty and I use Xfinity (comcast). I've tried unhooking everything and letting it power cycle about 5 times bit it still is not working. I assume I have a much larger issue. Sucks since Ibreally love the hardware.
