Acelona
Sep 10, 2023Aspirant
Nighthawk CAX80 Ethernet Ports Not Working
Recently bought a new TV. When I did I unhooked everything from my setup and was only running wi-fi for a few days after installation. Wi-fi works as it should but now none of the ethernet ports will ...
- Sep 16, 2023
And you did power OFF the modem for 1 minute then back ON?
I'd get to NG support and see if there is an RMA option:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Acelona
Sep 16, 2023Aspirant
It is oit of warranty and I use Xfinity (comcast). I've tried unhooking everything and letting it power cycle about 5 times bit it still is not working. I assume I have a much larger issue. Sucks since Ibreally love the hardware.
Acelona
Seems lile it continues to power cycle for a while. Is there a better time to interrupt and plug in ethernet? When the wi-fi lights come on, when its just the power light, etc?
