Acelona
Sep 10, 2023Aspirant
Nighthawk CAX80 Ethernet Ports Not Working
Recently bought a new TV. When I did I unhooked everything from my setup and was only running wi-fi for a few days after installation. Wi-fi works as it should but now none of the ethernet ports will ...
- Sep 16, 2023
And you did power OFF the modem for 1 minute then back ON?
I'd get to NG support and see if there is an RMA option:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Acelona
Sep 16, 2023Aspirant
Definately getting internet. Download speed tests at almost 400mb per sec. Just no ethenet ports
Sep 16, 2023Guru - Experienced User
- AcelonaSep 17, 2023AspirantUnbelievable, turns out my router was fine. My Series X on the otherhand has a bad ethernet port. Sorry for the trouble, I should have caught that.
- FURRYe38Sep 17, 2023Guru - Experienced User
Glad that was all. Good find.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerHope MS will fix that.
Good Luck.
