Y2kcurt
Mar 28, 2025Guide
Nighthawk CAX80 Intermittent internet disconnections
I am hoping someone can help. My Xfinity internet intermittently completely drops out, on both ethernet connections and Wifi, on avg, about 2-3 times per hour. However it will sometimes go a few hour...
- Apr 03, 2025
As a follow up and to close out this thread in case anyone else has similar issues, we finally identified the root cause and resolved the issue. The coax line from the cable provider (comcast) that goes from a box in my neighbors yard to my house was bad and needed to be replaced (which required running it underground). Once replaced all of the issues identified in this thread were resolved.
Thanks for your help!
Mar 28, 2025Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Y2kcurt
Mar 28, 2025Guide
| Description | Count | Last Occurrence | Target | Source |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:19:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [login] from source 192.168.1.92 | 1 | Fri Mar 28 19:18:02 2025 | 192.168.1.1:80 | 192.168.1.92:53375 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:17:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:17:56 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:443 DPT:38948 | 3 | Fri Mar 28 19:17:53 2025 | 76.154.153.101:38948 | 35.212.178.254:443 |
| [DHCP IP: 192.168.1.196] to MAC address 82:a0:e8:6b:42:d9 | 1 | Fri Mar 28 19:17:46 2025 | 192.168.1.196:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:17:28 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.53] to MAC address d0:3f:27:b7:e8:43 | 1 | Fri Mar 28 19:17:06 2025 | 192.168.1.53:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:16:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.68] to MAC address e8:9f:80:39:21:f2 | 1 | Fri Mar 28 19:15:57 2025 | 192.168.1.68:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.187] to MAC address 80:0c:f9:c1:0c:01 | 1 | Fri Mar 28 19:15:37 2025 | 192.168.1.187:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:14:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.176] to MAC address 44:bb:3b:04:e7:50 | 1 | Fri Mar 28 19:14:57 2025 | 192.168.1.176:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:5223 DPT:53109 | 2 | Fri Mar 28 19:14:50 2025 | 76.154.153.101:53109 | 17.57.144.102:5223 |
| [DHCP IP: 192.168.1.13] to MAC address 60:38:e0:ea:f3:d1 | 1 | Fri Mar 28 19:14:37 2025 | 192.168.1.13:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:13:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 19:13:57 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.107] to MAC address 64:16:66:40:21:cb | 2 | Fri Mar 28 19:13:21 2025 | 192.168.1.107:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:12:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.189] to MAC address 70:bc:10:65:9b:b6 | 1 | Fri Mar 28 19:12:23 2025 | 192.168.1.189:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:12:20 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.102] to MAC address d8:28:c9:8a:57:44 | 1 | Fri Mar 28 19:12:09 2025 | 192.168.1.102:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:11:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:11:55 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.145] to MAC address 98:17:3c:0b:03:bc | 1 | Fri Mar 28 19:11:08 2025 | 192.168.1.145:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.212] to MAC address 60:38:e0:49:8d:41 | 1 | Fri Mar 28 19:11:05 2025 | 192.168.1.212:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.219] to MAC address 14:91:82:49:6b:fd | 1 | Fri Mar 28 19:11:02 2025 | 192.168.1.219:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:10:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.134] to MAC address 78:28:ca:31:67:2c | 1 | Fri Mar 28 19:10:56 2025 | 192.168.1.134:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.71] to MAC address 60:38:e0:46:9a:35 | 1 | Fri Mar 28 19:10:30 2025 | 192.168.1.71:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:09:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:09:43 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 19:09:39 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:09:15 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:08:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.27] to MAC address d0:03:df:b5:2a:88 | 1 | Fri Mar 28 19:08:20 2025 | 192.168.1.27:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:07:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.19] to MAC address ca:6a:10:23:36:9c | 1 | Fri Mar 28 19:06:16 2025 | 192.168.1.19:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:06:07 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:05:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:05:38 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:04:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:03:30 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.105] to MAC address 50:c7:bf:03:e8:79 | 1 | Fri Mar 28 19:03:07 2025 | 192.168.1.105:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:03:02 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:02:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:01:13 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.154] to MAC address 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:01:13 2025 | 192.168.1.154:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.145] to MAC address 98:17:3c:0b:03:bc | 1 | Fri Mar 28 19:01:09 2025 | 192.168.1.145:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:00:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:00:53 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.154] to MAC address 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:00:51 2025 | 192.168.1.154:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:00:25 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:59:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:443 DPT:37132 | 2 | Fri Mar 28 18:59:15 2025 | 76.154.153.101:37132 | 52.37.185.175:443 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:58:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 18:58:51 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:58:11 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:57:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:57:42 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:57:37 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:56:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:8883 DPT:64858 | 2 | Fri Mar 28 18:56:16 2025 | 76.154.153.101:64858 | 40.112.221.115:8883 |
