Y2kcurt
Mar 28, 2025Guide
Nighthawk CAX80 Intermittent internet disconnections
I am hoping someone can help. My Xfinity internet intermittently completely drops out, on both ethernet connections and Wifi, on avg, about 2-3 times per hour. However it will sometimes go a few hour...
- Apr 03, 2025
As a follow up and to close out this thread in case anyone else has similar issues, we finally identified the root cause and resolved the issue. The coax line from the cable provider (comcast) that goes from a box in my neighbors yard to my house was bad and needed to be replaced (which required running it underground). Once replaced all of the issues identified in this thread were resolved.
Thanks for your help!
Y2kcurt
Mar 28, 2025Guide
| Description | Count | Last Occurrence | Target | Source |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:19:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [login] from source 192.168.1.92 | 1 | Fri Mar 28 19:18:02 2025 | 192.168.1.1:80 | 192.168.1.92:53375 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:17:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:17:56 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:443 DPT:38948 | 3 | Fri Mar 28 19:17:53 2025 | 76.154.153.101:38948 | 35.212.178.254:443 |
| [DHCP IP: 192.168.1.196] to MAC address 82:a0:e8:6b:42:d9 | 1 | Fri Mar 28 19:17:46 2025 | 192.168.1.196:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:17:28 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.53] to MAC address d0:3f:27:b7:e8:43 | 1 | Fri Mar 28 19:17:06 2025 | 192.168.1.53:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:16:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.68] to MAC address e8:9f:80:39:21:f2 | 1 | Fri Mar 28 19:15:57 2025 | 192.168.1.68:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.187] to MAC address 80:0c:f9:c1:0c:01 | 1 | Fri Mar 28 19:15:37 2025 | 192.168.1.187:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:14:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.176] to MAC address 44:bb:3b:04:e7:50 | 1 | Fri Mar 28 19:14:57 2025 | 192.168.1.176:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:5223 DPT:53109 | 2 | Fri Mar 28 19:14:50 2025 | 76.154.153.101:53109 | 17.57.144.102:5223 |
| [DHCP IP: 192.168.1.13] to MAC address 60:38:e0:ea:f3:d1 | 1 | Fri Mar 28 19:14:37 2025 | 192.168.1.13:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:13:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 19:13:57 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.107] to MAC address 64:16:66:40:21:cb | 2 | Fri Mar 28 19:13:21 2025 | 192.168.1.107:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:12:59 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.189] to MAC address 70:bc:10:65:9b:b6 | 1 | Fri Mar 28 19:12:23 2025 | 192.168.1.189:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:12:20 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.102] to MAC address d8:28:c9:8a:57:44 | 1 | Fri Mar 28 19:12:09 2025 | 192.168.1.102:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:11:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:11:55 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.145] to MAC address 98:17:3c:0b:03:bc | 1 | Fri Mar 28 19:11:08 2025 | 192.168.1.145:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.212] to MAC address 60:38:e0:49:8d:41 | 1 | Fri Mar 28 19:11:05 2025 | 192.168.1.212:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.219] to MAC address 14:91:82:49:6b:fd | 1 | Fri Mar 28 19:11:02 2025 | 192.168.1.219:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:10:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.134] to MAC address 78:28:ca:31:67:2c | 1 | Fri Mar 28 19:10:56 2025 | 192.168.1.134:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.71] to MAC address 60:38:e0:46:9a:35 | 1 | Fri Mar 28 19:10:30 2025 | 192.168.1.71:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:09:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:09:43 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 19:09:39 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:09:15 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:08:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.27] to MAC address d0:03:df:b5:2a:88 | 1 | Fri Mar 28 19:08:20 2025 | 192.168.1.27:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:07:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.19] to MAC address ca:6a:10:23:36:9c | 1 | Fri Mar 28 19:06:16 2025 | 192.168.1.19:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:06:07 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:05:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:05:38 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:04:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:03:30 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.105] to MAC address 50:c7:bf:03:e8:79 | 1 | Fri Mar 28 19:03:07 2025 | 192.168.1.105:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:03:02 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 2 | Fri Mar 28 19:02:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:01:13 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.154] to MAC address 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:01:13 2025 | 192.168.1.154:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.145] to MAC address 98:17:3c:0b:03:bc | 1 | Fri Mar 28 19:01:09 2025 | 192.168.1.145:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 19:00:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:00:53 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.154] to MAC address 90:48:6c:1c:6f:cc | 1 | Fri Mar 28 19:00:51 2025 | 192.168.1.154:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 19:00:25 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:59:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:443 DPT:37132 | 2 | Fri Mar 28 18:59:15 2025 | 76.154.153.101:37132 | 52.37.185.175:443 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:58:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.127] to MAC address 58:ef:68:dc:91:dd | 1 | Fri Mar 28 18:58:51 2025 | 192.168.1.127:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:58:11 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:57:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [WLAN access rejected: incorrect security] from MAC 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:57:42 2025 | 0.0.0.0:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.216] to MAC address 18:b4:30:69:c7:e7 | 1 | Fri Mar 28 18:57:37 2025 | 192.168.1.216:0 | 0.0.0.0:0 |
| [DHCP IP: 192.168.1.48] to MAC address 44:67:55:26:c8:d8 | 1 | Fri Mar 28 18:56:58 2025 | 192.168.1.48:0 | 0.0.0.0:0 |
| [DoS attack] ACK scan SPT:8883 DPT:64858 | 2 | Fri Mar 28 18:56:16 2025 | 76.154.153.101:64858 | 40.112.221.115:8883 |
Y2kcurt
Mar 28, 2025Guide
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Fri Mar 28 18:30:41 2025
Startup Procedure
Acquire Downstream Channel: 633 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 44 633000000 Hz 2.1 dBmV 42.8 dB 24100 15287
2 Locked 256 QAM 13 447000000 Hz 1.2 dBmV 44 dB 118447 61264
3 Locked 256 QAM 14 453000000 Hz 1.4 dBmV 44.1 dB 113631 58881
4 Locked 256 QAM 15 459000000 Hz 1.5 dBmV 44.2 dB 19507 17886
5 Locked 256 QAM 16 465000000 Hz 1.3 dBmV 42.7 dB 90210 44731
6 Locked 256 QAM 17 471000000 Hz 1.2 dBmV 43.1 dB 105298 52698
7 Locked 256 QAM 18 477000000 Hz 1.7 dBmV 43.9 dB 17133 19245
8 Locked 256 QAM 19 483000000 Hz 1.5 dBmV 43.8 dB 73610 35490
9 Locked 256 QAM 20 489000000 Hz 1.3 dBmV 39 dB 110055 53740
10 Locked 256 QAM 21 495000000 Hz 1.6 dBmV 39.4 dB 19793 20373
11 Locked 256 QAM 22 501000000 Hz 1.7 dBmV 41.6 dB 57749 26718
12 Locked 256 QAM 23 507000000 Hz 1.5 dBmV 44 dB 94021 46138
13 Locked 256 QAM 24 513000000 Hz 1.5 dBmV 44 dB 16139 20462
14 Locked 256 QAM 25 519000000 Hz 1.6 dBmV 43.5 dB 41380 20494
15 Locked 256 QAM 26 525000000 Hz 1.9 dBmV 43.7 dB 89840 41973
16 Locked 256 QAM 27 531000000 Hz 2.2 dBmV 44.2 dB 15096 22179
17 Locked 256 QAM 28 537000000 Hz 1.9 dBmV 43.9 dB 34506 17484
18 Locked 256 QAM 29 543000000 Hz 1.6 dBmV 43.8 dB 79241 37505
19 Locked 256 QAM 30 549000000 Hz 2 dBmV 44.1 dB 15740 24750
20 Locked 256 QAM 31 555000000 Hz 2.1 dBmV 43.3 dB 23964 13263
21 Locked 256 QAM 32 561000000 Hz 1.8 dBmV 34.4 dB 86410 37744
22 Locked 256 QAM 33 567000000 Hz 2 dBmV 40.9 dB 15352 23496
23 Locked 256 QAM 34 573000000 Hz 2.4 dBmV 41.8 dB 15978 10824
24 Locked 256 QAM 35 579000000 Hz 2.1 dBmV 43.7 dB 51016 26882
25 Locked 256 QAM 36 585000000 Hz 2.3 dBmV 43.3 dB 12672 23423
26 Locked 256 QAM 37 591000000 Hz 2.4 dBmV 41.2 dB 12255 10048
27 Locked 256 QAM 38 597000000 Hz 2.3 dBmV 41.4 dB 38860 21116
28 Locked 256 QAM 39 603000000 Hz 2.3 dBmV 42.6 dB 12794 22524
29 Locked 256 QAM 40 609000000 Hz 2.3 dBmV 43.2 dB 10299 9237
30 Locked 256 QAM 41 615000000 Hz 1.9 dBmV 43.6 dB 31678 18808
31 Locked 256 QAM 42 621000000 Hz 2.3 dBmV 43.6 dB 12017 20904
32 Locked 256 QAM 43 627000000 Hz 2.5 dBmV 43.5 dB 8399 8338
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 20 5120 Ksym/sec 35600000 Hz 41.0 dBmV
2 Locked ATDMA 18 5120 Ksym/sec 22800000 Hz 41.0 dBmV
3 Locked ATDMA 19 5120 Ksym/sec 29200000 Hz 41.0 dBmV
4 Locked ATDMA 17 5120 Ksym/sec 16400000 Hz 41.0 dBmV
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 193 722000000 Hz 3.38 dBmV 43.5 dB 328 ~ 3767 1703976097 450254190 330749
2 Locked 0 ,1 ,2 ,3 194 957000000 Hz 4.08 dBmV 43.6 dB 148 ~ 3947 1746128284 325347540 103554
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
2 Not Locked 0 0 0 Hz 0 dBmV
