RRATHBUN
Dec 01, 2022Aspirant
Nighthawk CAX80 login loop
When is Netgear going to properly fix the issue with the login loop associated with the CAX80 web interface? It seems well known across these forums that the problem exists, but I have yet to see Net...
Dec 01, 2022Guru - Experienced User
Only seen this if the browser has the log in information incorrectly stored with in the browser or the page was cached and not cleared fully before logging in.
Be sure you clear the browsers cache and clear any saved log in profile tor the CAX80. Once I cleared mine out of the browser, the log in worked.
Try a different browser.
Be sure to type in the correct PW values correctly.
RRATHBUN
Dec 12, 2022Aspirant
Using the following software / firmware:
Firmware: v2.1.5.2
Browser: Microsoft Edge version 108.0.1462.46 (Official build) (64-bit)
Actions taken:
1. Password properly set (was always correct)
2. Cleared cache
3. No saved passwords in edge
Symptoms:
1. Attempt to login using user ID and password - fails
2. Retry over and over, and eventually and VERY inconsistently the system lets me in
3. Almost always sends me to the password reset page.
If anyone from NETGEAR wants any advanced logging I'll happily share. I work in IT for a living, and this is well beyond your basic home user troubleshooting issues. Also, I can get to the device using my iPhone without any issues.
