RRATHBUN
Dec 01, 2022Aspirant
Nighthawk CAX80 login loop
When is Netgear going to properly fix the issue with the login loop associated with the CAX80 web interface? It seems well known across these forums that the problem exists, but I have yet to see Net...
MusicWithMarky
Dec 31, 2022Aspirant
Same issue here. Two different wired computers, multiple browsers tried and nothing lets me get out of the password reset loop. I have the mesh system attached for wireless and when I try to login from those devices, I am able to get to the admin area, but then I'm only seeing the wireless activity. I'm not sure how to resolve this wired one.
RRATHBUN
Jan 01, 2023Aspirant
Ensure you're on the latest firmware. If all else fails try repeatedly and it should let you in. Mine seems to have resolved itself, but am unsure of the true root cause.
- MusicWithMarkyJan 02, 2023Aspirant
Unfortunately, I have tried repeatedly (which is tiring, given I have to do the pass and security questions each time) and to no avail. It is on the latest FW as well. Is there a hard reset I should consider?
- FURRYe38Jan 02, 2023Guru - Experienced User
15 second press on the reset button then release then clearing the broser caches and save password profiles for the modem doesn't get you to the setup wizard screen at 192.168.1.1 at all?
