RRATHBUN
Dec 01, 2022Aspirant
Nighthawk CAX80 login loop
When is Netgear going to properly fix the issue with the login loop associated with the CAX80 web interface? It seems well known across these forums that the problem exists, but I have yet to see Net...
RRATHBUN
Jan 01, 2023Aspirant
Ensure you're on the latest firmware. If all else fails try repeatedly and it should let you in. Mine seems to have resolved itself, but am unsure of the true root cause.
MusicWithMarky
Jan 02, 2023Aspirant
Unfortunately, I have tried repeatedly (which is tiring, given I have to do the pass and security questions each time) and to no avail. It is on the latest FW as well. Is there a hard reset I should consider?
- FURRYe38Jan 02, 2023Guru - Experienced User
15 second press on the reset button then release then clearing the broser caches and save password profiles for the modem doesn't get you to the setup wizard screen at 192.168.1.1 at all?
