uptownvideo
Feb 14, 2023Apprentice
Nighthawk CAX80 loses internet
I have the CAX80 wifi router with Cox cable plugged in to it. My wife works from home and has been getting kicked off out her Zoom/Teams meetings. She tried 2 different computers and it happened on...
uptownvideo
Firmware is V2 1.5.2
The PC is connected using WiFi
It is set to Auto is currently on channel 4 and 5G is 36. The WiFi is set to Smart Connect.
Neighbors are close by since we live on a cul-de-sac with small yards.
Feb 15, 2023Guru - Experienced User
Does it happen if the pc is hardwired in?
Or only over wireless?
- uptownvideoFeb 19, 2023Apprentice
This has not happened while plugged in. WiFi is the only option for the computer that is had issues. I changed channels and so far there have not been any internet issues.
