FlatheadLake
Dec 29, 2020Guide
Nighthawk CAX80 male barrel connector power plug size
What size is the size of the male barrel connector on the DC power cable that comes with the CAX80 modem/router? It appears to be 7 to 7.4mm outer diameter, 5 to 5.1mm inner diameter. Does anyone k...
- Dec 30, 2020
7.4mm/5.1mm
Dec 30, 2020Guru - Experienced User
Try looking at the spec sheet or the user manual to see if the plug size is listed. Or take a dial caliper measuring device to check the size.
- FlatheadLakeDec 30, 2020Guide
FURRYe38 wrote:Try looking at the spec sheet or the user manual to see if the plug size is listed. Or take a dial caliper measuring device to check the size.
Thank you, FURRYe38, I have gone through all of the documentation thoroughly, as have the Netgear Support people I have spoken with, to no avail. I will look for a caliper and give that a shot, but I am still hoping to get the official statement from Netgear. Even just knowing the diameter of the pin in the input connector on the CAX80 router/modem would help. Thanks again.
