FlatheadLake
Dec 29, 2020Guide
Nighthawk CAX80 male barrel connector power plug size
What size is the size of the male barrel connector on the DC power cable that comes with the CAX80 modem/router? It appears to be 7 to 7.4mm outer diameter, 5 to 5.1mm inner diameter. Does anyone k...
- Dec 30, 2020
7.4mm/5.1mm
My_Username
Dec 30, 2020Apprentice
7.4mm/5.1mm
FlatheadLake
Dec 30, 2020Guide
Thank you so much! One Netgear support person responded with the same size, 7.4 OD, 5.1 ID. I will proceed with this and see how it goes. As a note however another Netgear support person responded that it was 7.9 OD and 5.5 ID. This seemed too large base on the best MM stick measurements I could execute short of a caliper. I am also only findinng cunnectors available at 7.4mm OD and and even 5.0mm ID. I have orded two different brandsnat this 5.0mm ID size and will report back how it fits. Thank you again and to all others who have replied!
