JEdgeston
Sep 29, 2022Aspirant
Nighthawk CAX80 not connecting to the internet (Mediacom)
I moved to Pontiac, Il in June 2021. Once I was moved to Pontiac, I had to use the local ISP call Mediacom. Did research to find out that my Nighthawk CAX80 modem\router was approved to be setup on M...
Sep 29, 2022Guru - Experienced User
What are the front LEDs showing?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
JEdgeston
I discussed this issue with Netgear. I was informed that the agent has a fix for this issue, but would not tell me if this was a setting needed to be configured or provide a patch to correct this issue unless I paid a year support subscription. Is there another business in his world that has a bug in a product they produced, but holds their user hostage so that they can milk more money from their customers.
All of the things that was discussed in the response here was already done...
- FURRYe38Sep 29, 2022Guru - Experienced User
Well if your in contact with NG support then you'll need to follow up with them then.
Good luck.
- plemansSep 29, 2022Guru - Experienced User
Most people don't actually get a hold of netgear support and end up on some scam/con site.
Not saying its not as outside of the 90 days it does cost money. But they usually don't say "I have a fix, buy XYZ and we'll do it"
Its usually a charge up front if the device doesn't boot.
so I'd be a bit leary.
Do you have a screen snip of the cable connections page and event logs?
- JEdgestonSep 30, 2022Aspirant
Right now my Nighthawk CAX80 router\modem is not connected to the Mediacom network. I'm using a Mediacom router\modem because I was forced to get out of desperation. I will be reconnecting the Nighthawk to the network on Saturday Oct. 1, because I don't want to pay an additional cost for Mediacom's router\modem. Once I have back on the Mediacom's network I will send you the Cable Connection information.
- JEdgestonOct 13, 2022Aspirant
The issue is there is no gateway settings being established when the router\modem is rebooted.
Here is what I found out. The issue only happens when the router\modem gets rebooted or a power outage. What I have to do to resolve the issue is the following:
1. Reset the router\modem to factory settings.
2. Call my ISP to remove the router\modem from their network.
3. Have the ISP readd the router\modem to the network.This will work awhile until the router\modem is reset again... Then I will have to start the process over again. Is there anyone in this forum doing the same thing? If so, have your issue been resolved? What was your resolution to this issue?
