chris-linux's avatar
chris-linux
Nighthawk CAX80 not issuing new IPs
I have had the Nighthawk CAX80 for just one year and had several issues with this router. This time I happened to be traveling and working remotely. The issue is  that the router is not issuing new IP addresses. I have several machines and an esxi host, when i create a new VM nothing works, no new IP whastover. I thought the issue was the DHCP, but when I check it says everything is working properly. Is there anything i can do to make this work? To get the DHCP to issue IPs? I rebooted several time times and so far nothing is working.
  • plemans's avatar
    do you have issues for devices that aren't VM's?
    • chris-linux's avatar
      chris-linux
      The devices that are not VMs have had the same IP for the last few months until i changed the Subnet. But even when I reboot the router the non VM devices maintain their IPs. But these IPs are not static.
      • plemans's avatar
        Basically I'm curious if you connect a new (non-VM) device to the router,is it assigned an IP address?
        What are you setting with static ip addresses?
        Any other devices on your network acting as a DHCP server? (managed switch, access point that might not be in access point mode)
