FlatheadLake's avatar
Dec 29, 2020
Nighthawk CAX80 Outboard Power Supply Connector Size?
I am replacing the power supply on my Nighthawk CAX80 modem/router and need to know the size of the connector on the current power supply cable.  The connecter plugging the power supply into the CAX80 modem/router.  As close as I can measure it appears to be 7.4 mm outer diameter, 5.1 mm inner diameter.
Does anyone know if this is correct?   Thank you in advance for any and all assistance.
