proscancomcast
May 06, 2022Follower
Nighthawk CAX80 slow speeds on Xfinity
I am from West Michigan and have Precisely the same problem. I live in a suburban home and do NOT have any splitters or bad coax
My provider is Xfinity and have had both Netgear on this (they ...
May 06, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Be sure your using a good quality LAN cable between the CAX80 and your PC. CAT6A UTP if your connecting to a 1Gb LAN port on the CAX80. CAT6A STP if your connecting to the multi-gig port on the CAX80.
Be sure your ethernet drivers are updated on the PC.
