FlatheadLake
Feb 06, 2022Guide
Nighthawk CAX80 USB 3.0 Not Recognized
Connecting my HP Windows 10 laptop to the Nighthawk CAX80 Modem/Router using a USB 3.0 high speed connecter, I am getting the error message Windows does not recognize the USB attached device. This c...
Feb 07, 2022Guru - Experienced User
Clarification.
Are you connecting to the CAX80's usb port and going usb<----->usb or is your adapter connected to the HP's usb port and is a usb--->ethernet adapter?
FlatheadLake
Feb 07, 2022Guide
Thank you for asking. Yes, I am connecting directly from the HP Envy x360 USB 3.0 port to the Nighthawk CAX80 USB 3.0 port using a high speed USB 3.0 type A male to type A male extension cable.
Will a USB to Ethernet adapter work? Thank you.
