JohnGreen97
Nov 28, 2024Follower
Nighthawk CAX80 use ethernet instead of cable to access Internet
Can I have the nighthawk CAX80 use a ethernet cable attached to a modem to access the internet instead of the coaxial cable? I don’t like that Xfinity won’t let me change DNS, and I have a CAX80 from ...
Nov 29, 2024Guru - Experienced User
1. you can change your dns. I do it all the time.
2. If its not removed from the neighbors account and they're on xfnity, if you connect it, it would work at your place. They only add the mac to their system. So if its still active on his account it'd work. If it doesn't work, it isn't active on his account.
3. Have you tried to have it activated to your account either through the xfinity app or using their chat function? Where does it fail in the process?
