TechMiner
Jan 20, 2023Aspirant
Nighthawk CAX80 VLAN Compatability
Hello all! Thank you first of all for any help offered. I want to connect the CAX80 WAN port directly to a VLAN port on a Cisco switch. What I'm trying to do is connect a WAN port from a Mo...
Jan 20, 2023Guru - Experienced User
The CAX80 doesn't have a ethernet WAN port. The CAX80 requires the use of the RG6 cable coax signal connection for it to work.
- TechMinerJan 20, 2023Aspirant
Wow,
Thank you for this amazingly quick reply FURRYe38!
So the LAN (Multi-Gig 2.5/1G) is used for what sir?
TechMiner.
- plemansJan 20, 2023Guru - Experienced User
Just for that, a LAN port.
The CAX80 needs a coaxial input or it goes into a boot loop.
If you already have services coming in, you don't need a modem/router combo device. You just need a router.
