Ming58
Apr 15, 2024Aspirant
Nighthawk CAX80 won't save configuration data.
I purchased a Nighthawk CAX80 cable modem/router a little over 2 months ago. Netgear support is absolutely useless. The CAX80 will not save the configuration data. I cannot change the ipaddress fo...
Apr 15, 2024Guru - Experienced User
Something to try, reload the same FW version on to the modem with a wired PC.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
After it's back to ready, reset the modem and setup from scratch using the erase button:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Be sure to clear out all browser caches.
Then walk thru the setup routine with same wired PC and web browser. Set up the system for your needs.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Then save off a back up configuration to file soon after all has been setup:
Let us know if you can get this completed.
Ming58
I'll give it a go but I originally did all of the configuration with a wired PC. I don't trust WIFI for that kind of work.
Wiped and factory reset it before the second configuration. But I didn't consider any browser caches.
- FURRYe38Apr 15, 2024Guru - Experienced User
Same here, wired is preferred for this.
