Kellest1FollowerAug 27, 2020Nighthawk cm1100Hi,Is the Nighthawk cm1100 compatible with Magic jack ?Thank you
1 ReplyReplies sorted by OldestFURRYe38Guru - Experienced UserAug 27, 2020You need a wifi router in between the CM modem and the majic jack. If you have one, then yet, MJ will work. Mine did.
