BobatEP's avatar
BobatEP
Nighthawk CM1150
How do I unlock port #2 on the CM1150V  to connect my RedLINK  internet gateway to the internet?  I've hardwired the two devices and an amber light appears on port #2.  I believe the next step is to ...
  • FURRYe38's avatar
    I presume if you connect the other device on WAN port#1 as a test that it will work after the modem is rebooted?
    Hopefully your ISP can allow a 2nd WAN IP to the modem.
