BobatEP
Mar 05, 2021Aspirant
Nighthawk CM1150
How do I unlock port #2 on the CM1150V to connect my RedLINK internet gateway to the internet? I've hardwired the two devices and an amber light appears on port #2. I believe the next step is to ...
- Mar 14, 2021
I presume if you connect the other device on WAN port#1 as a test that it will work after the modem is rebooted?
Hopefully your ISP can allow a 2nd WAN IP to the modem.
TrunkMonkey
Mar 22, 2021Tutor
I've inquired about this as well and have found that since the 1150v is a modem only, no router, only port 1 is active. Not sure if going the Comcast business route or paying for a second IP or static IP pool will get you a second port or if Comcast would know how to enable the second port.
Mar 22, 2021Guru - Experienced User
All that would be needed is to give them the MAC address of the modem and reboot the modem once they give out a 2nd IP address. The modem should see a WAN IP address on the 2nd port after the reboot. You'll need either a wired PC or another router connected to the 2nd port to check the service.
TrunkMonkey wrote:I've inquired about this as well and have found that since the 1150v is a modem only, no router, only port 1 is active. Not sure if going the Comcast business route or paying for a second IP or static IP pool will get you a second port or if Comcast would know how to enable the second port.
