rsherma
Apr 11, 2023Aspirant
Nighthawk CM1150V cannot get expected speed
Xfinity increased my speed to 800 Megabits (download), however when I am directly connected to the modem (by passing my router), and at best, I am only getting 400 Megabits. This was the 3rd party m...
Kitsap
Apr 17, 2023Master
rsherma wrote:Thanks very much for your reply. I am using cat 5e cable. Very interesting about Dell not using a 10/100/1000 port on their newer machines. I have double checked my Dell and Modem drivers to make sure they are current. I will try buying a USB to Ethernet adapter and see if that improves speed at all. I will provide an update after trying this.
Not what I said! If your computer is equipped with a 10/100/1000 Mbps rated port, the most your are going to get through it in real life is around 940-950 Mbps. The reason is the ports run at about 94-95% efficiency, thus the max throughput in the 940-950 Mbps range.
rsherma
Apr 17, 2023Aspirant
I would be more than happy with that speed. Hardwired, on a good day I might get 250-300, where my service is supposedly 800.
- KitsapApr 17, 2023Master
rsherma wrote:I would be more than happy with that speed. Hardwired, on a good day I might get 250-300, where my service is supposedly 800.
What is the brand name and model number of the router you are connecting to?
In the configuration of your modem, do you have link aggregation enabled? If yes, it should not be.
You are getting to the point where you will need to post cable connection page and event log information from your modem.
It is helpful to copy and paste information from your configuration interface to a word processing program. Adjust the margins and font size so it is readable and save to a pdf for attaching to your reply.
