JohnM82
May 17, 2024Aspirant
Nighthawk CM1150V Firmware
Is there a firmware update for the nighthawk CM1150V? I'm having issues with my Xfinity/Comcast wifi lately and the technicians suggested I do the update. Cannot find one in downloads. Before assu...
May 17, 2024Guru - Experienced User
The ISP has to do that, if they will for user owned modem:
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- JohnM82May 17, 2024Aspirant
Thank you for responding.
Using Google Nest Pro for router/wifi function. Using cat cable that came in box, don't know if it is 5 or 6.
First tech I spoke with at comcast said I need to do firmware upgrade.
- FURRYe38May 17, 2024Guru - Experienced User
For C and CM series modems, only ISPs can update FW.
