JohnM82
May 17, 2024Aspirant
Nighthawk CM1150V Firmware
Is there a firmware update for the nighthawk CM1150V? I'm having issues with my Xfinity/Comcast wifi lately and the technicians suggested I do the update. Cannot find one in downloads. Before assu...
JohnM82
Thank you for responding.
Using Google Nest Pro for router/wifi function. Using cat cable that came in box, don't know if it is 5 or 6.
First tech I spoke with at comcast said I need to do firmware upgrade.
May 17, 2024Guru - Experienced User
For C and CM series modems, only ISPs can update FW.
