ReidHJ
Oct 23, 2022Aspirant
Nighthawk cm1200 and Sony Bravia
Looking for some help- thank you! When connecting to WiFi: Connected Network does not have access to internet: failed When connecting with an Ethernet cable or hotspot: Connected Network has...
Oct 23, 2022Guru - Experienced User
The CM1200 is a modem only device.
It has no routing capability.
So you need to go modem----->router---->devices
And the vast majority of ISP's can only connect 1 device to the cm1200 (even though it has more ports).
So if you had more than 1 device connected, power off the modem and router and disconnect everything from both.
wait 2 minutes
Power the modem on with nothing connected.
Wait 2 minutes
connect port 1 on the modem to the router.
power the router on and wait 2 minutes.
go through setup on the router
- ReidHJOct 23, 2022AspirantThank you! Tried your great suggestions. Unfortunately no luck. I will either upgrade router or depend on Ethernet for this devise.
Appreciate your time and input.
Reid
